1 - 7 of 7 Posts
sellstuff
Discussion starter · #1 ·
We've got a 1990 Carrier 58GSC model HVAC gas furnace / AC that still has it's original twin Mercury switch Thermostat. This Carrier Furnace/AC is a 4-wire connection to the Thermostat and I'm having a tough time finding a good but cheap Digital Thermostat with many 3 to 5 programmable setup that's 4-wire or states in the advertising specs that it is compatible with a 4-wire furnace.
This Honeywell carried at Lowes is what I'm looking for, but it says no where whether it's 4-wire compatible. https://www.lowes.com/pd/Honeywell-Basic-Digital-Programmable-Thermostat/3464340
Any suggestions out there for a particular brand or model that's 4-wire compatible similar to the Honeywell referenced above in the $30 to $45 price range?
Most basic thermostats are 4 wire.
If you have the letters R, y, G, W at the stat, you can use any.
You can often use fancier t-stats with 4 wire systems, you just program them properly for the system type.
Discussion starter · #4 ·
I have a new in the box Honeywell CT2400A I bought about 10 years ago for another house I owned and never used it. It is for 4-wire systems, BUT it says it's for "24 volt systems".
How do I determine if my Carrier 58GSC model HVAC gas furnace / AC is 24 VAC? I don't see any reference on the schematics to the voltage for this system?
This is the PDF for the Carrier 58GSC Furnace. http://dms.hvacpartners.com/docs/1005/Public/03/58GSC-5SI.pdf
Honeywell CT2400A Digital Therm
All the controls are on 24v ac, not dc.
thermostat, relays, contactors, gas valve, ignition control.
1 - 7 of 7 Posts
