Doing this ASAP (this weekend) so I'm looking to get some final feedback on my thoughts.
This is for our 10ft x 20ft 1950 detached garage that has 3 walls of CMU block with the upper 5 courses being brick. (PLEASE PLEASE PLEASE let us know if we got something wrong!) Our slope is 5in over 20feet. I but believe that is right at the cut off for doing 2-ply over 3-ply so we're just going to do the 3-ply.
Seems to be 2 ways of doing the 3-ply. Either 2ply of base with 1 ply of cap OR laying down a mechanically attached Liberty Base sheet to the 1/2" plywood deck we have.
That sounds easier and cleaner than having to asphalt prime the whole plywood deck, no?
Is Liberty MA base the same thing as asphalt felt? Can I use say a 30lb asphalt felt or something similar?
So we need to manually nail down a ply of the Liberty MA Base sheet.
Then, 1 ply of the Liberty Base/Ply Sheet (which is Peel-n-stick, right? no primer when it goes on the MA base?)
And then 1 ply of the Liberty Cap Sheet (which is also Peel-n-Stick, right?)
Now the detail questions:
GAF Flashing Cement (Matrix 201) and Asphalt Primer (Matrix 307) – how do these items compare to the Karnak brand's flashing cement and asphalt primer? Will there be a compatibility issue with the Liberty Peel-n-stick?
Cant strip - Do you guys make your own 45-degree wood cants? Do you actually buy the cant strips i.e. “Energyguard cant” as detailed in the GAF instructions? Is there some way to make your own? Run them on a table saw at a 45-degree using a 4x4 pressure-treated post seems like it would take too may passes...
Is a weight hand roller (for the seams) necessary? Okay just to walk (toe-to-heel) along the seam (220lb person?)
Prepping parapet – right now there is old black (tar?) stuff on the CMU/Brick parapets. I assume there is no real way to clean it off so just put Asphalt Primer all over first?
CMU parapet has open holes on top – do I need to put down metal flashing over those holes, before laying down asphalt primer and then base&cap?
Thanks so much guys!
