I bought an inexpensive Stanley optical level for laying out my house on the lot. It worked pretty well for getting grade drawings and placing the structure in rough position.
The bearing markers are not exactly consistent around the dial making it hard to precisely move to specific angles. In one test, I could move away from a point and then move back to the same half-degree angle as precisely as I could interpolate between the lines and found that, at 40 feet out, I was up to 3 or 4 inches from the previous reading.
That gets me close enough for getting the bulldozer in tomorrow to level a starting point but once he's gone, I need to lay out the footings exactly. 3 inches now will be an expensive error.
I know how to do 3-4-5 or 6-8-10 angle measurements or diagonals across a square or rectangle. And if our 22.5 degree turn in the front of the house turns out to be 22 or 23, it isn't the end of the world but the 90's have to be right. And with the 3-4-5 or diagonals, there is still some error for tape stretch or sag.
I uploaded our floor plan to http://www.debndale.com/images/house/firstfloorplan.jpg
So, if I want to have really square corners, I need help on how to do it. Please share your tips for precision layout - preferably on a budget but, if necessary, I can rent or buy a better quality level or transit. Suggestions on make/model would be great, if that is the key.
Thanks,
Dale
Thanks,
Dale
