Kerdi & Microcement
4 reading
3.8K views 19 replies 12 participants last post by  ugoogoli
I’m working on a bathroom remodel. For ease of execution I’m planning on using Schluter products for my shower pan, and we want to microcement our walls. Has anybody applied a microcement (such as Surecrete) over Kerdiboard or Kerdi membrane, or know if this can be done?
If not possible, I’m thinking my other option is to use Kerdi for the shower pan only, and cement boards for the walls. If I go this route, I’m thinking I would install the cement boards, seal with redguard, then install the shower pan with Kerdi and at the seams against the redguard. After this is all done I’d come back to microcement the walls. Does this sound like the right steps if a total Schluter setup can’t work?
TIA for this group’s collective wisdom!
#8 ·
I've never heard of microcement either. But after looking it up, my assumption would be this: it wouldn't be a good choice over KerdiBoard. However I can't see any reason it wouldn't be fine over cement board covered with Kerdi membrane. So build your shower as usual with Kerdi pan, cement board, Kerdi membrane, and the standard KerdiBand and corners. Then simply apply the microcement on top of that instead of tile.
I would call Schluter technical support to check.
#11 ·
I have redone 2 bathrooms down to studs and placed drywall (made for wet areas), sealed all corners and joins with silicone. Red guard up the walls about 12” and covering the floor (cement floor in both) then venetian plaster (one bathroom) and microcement (other bathroom) on the walls and the floors.
Both bathrooms curbless to drain with rounded edges at wall/floor intersections to make cleaning easier. The whole bathroom (again, very small) is like a big bathtub technically.
I searched the wilds of the internets to sort out the details prior but so far its been great and I would change nothing.
#19 ·
I just had an email exchange with Schluter US cust svc. They still do not support microcement over kerdi products. They say they haven't tested it.
I can't imagine that it wouldnt work other than maybe an adhesion issue.
I have been searching online for successful micro over kerdi membrane but not much luck. Especially over time.
