Is it ok to use red wire nut to cap one 12AWG wire?
13K views 15 replies 9 participants last post by  tylernt
Title says it all. Is it ok to use a red wire nut to cap ONE 12 gauge wire? :huh:
Or is a smaller wire nut needed to cap one 12 gauge wire?
#7 ·
That's very good to know; thank you very much.
I'm going to get an assortment pack of wire nuts from home depot that will include blue, orange, yellow, and red wire nuts. I'll use orange ones for capping wires.
Does anyone know who manufactures the wire nuts that home depot sells under their own brand ("Commercial Electric")?
#8 ·
Easy 3 step process to figure out if the nut fits.
1. Attempt to screw the wirenut onto the wire(s)
2. If it does not fit, check to see if the wirenut is too big or 2 small & adjust accordingly.
3. If it does fit, then you have the correct size wirenut.
Not a hard process. If the nut will screw down & hold securely, then it fits. That said, most red color ones I have, do not usually hold a single 12G wire well. But, try & see.
#11 · (Edited)
"It's a nut. It should hold tight like a nut.'
How come this 10-24 galvanized hex nut does not stay on my 8-32 brass machine bolt and hold the bracket to the sheet metal?
If the wire end happens not to have the last 1/2 inch stripped of insulation then a slightly oversized wire nut may screw sufficiently tightly over the insulation of the single wire end prior to curling up the latter to stuff into the box unused.
If the wire nut keeps on spinning suggesting stripped threads then it is not good enough.
Do not snip off unused wire ends except from old or knob & tube wiring that is being decommissioned.
#14 ·
Today I got the wire connectors and replaced the red wire nuts with orange ones. Then ran out and used blue for the few #14 wires left.
I stripped the few wires that were not stripped so that the wire nut would screw on the metal and not the insulation.
These Buchanan Wire-Twist connectors aren't really good for capping single wires because if you keep twisting, the spring screws through the top. Here's the thread
Is there any way to set a thread to resolved on this forum or do I just leave it alone?
#16 ·
This is what I do. Cap #12 with orange and #14 with blue. I dunno if it's code but it works a lot better, has a lot stronger bite, than using yellow to cap #12 and orange to cap #14.
Yellow to cap #12 and orange to cap #14 works a little better if you do not strip the insulation off the end of the conductor, but now your nut is biting into insulation and not copper and I don't think that's very secure.
