I know there is code that says a water supply line cannot pass over an electrical panel. If you need to run a horizontal water supply line across a panel you have to do it below the panel.
I am going to be redoing my supply lines in PEX (currently in PB), the new PEX manifold will be in my garage. However, where I am planning to have the new PEX hot and cold manifolds will be directly above (18" to 24") above a wiring trough box.
This trough box is a NEMA 3R, IP24 approved enclosure. There is no device (switches, receptacles) on it, only wire splices inside.
Obviously I have already considered other locations but that location is the best location except for the fact that it is directly above a wiring trough.
Is there code against the placement of water supply lines with respect to a wiring trough? If so is that electric code (NEC) or plumbing code (IPC/UPC)?
