I'm planning to widen a single door to double doors leading into a master bedroom. My plan is to frame and hang the doors such that they're 1.25 inches above the sub-floor. That will provide room for padding, carpet and a small gap.
My conundrum is as follows: The flush bolts that I've seen on line, when fully extended only protrude from the bottom about an inch or less. I don't want to lower the doors because they'll drag on the carpet. I'd prefer not to add a threshold between the doors for the bolt to catch in to. And I haven't seen any flush bolts with a long throw.
I suspect that there is a really obvious solution but I'm not seeing it.
Thanks in advance for your help!
