Installing a J-Block
24K views 9 replies 6 participants last post by  Tom Struble
I can't seem to figure out what I need to get my exterior light fixtures up. I have vinyl siding and the framing is exposed on the inside of the garage. If I use a J-block, should it have the built in box or can I use a plain face j-block with a round ceiling fixture box to mount the fixture to???
#4 ·
Can one of the blue, plastic, round carlon boxes be used or should it be a metal box?? The blue plastic box doesn't seem very sturdy for an outside fixture subject to wind and whatever else. Although, I guess the fixture would mostly be supported by by the j-block being fastened to the wall.
#7 ·
Both blocks above are made to fit over Double Lap siding without having to remove the siding. You could of course buy the blocks that install by removing a piece of siding, cutting the siding, securing the block and reinstalling the siding.
#8 ·
So I bought some J-blocks made by Arlington that will be installed under the siding and then cut the siding to fit. Are there tips or advice anyone can offer for cutting the siding? Using tin snips, jig saw, razor knife???
#9 ·
Leave a 3/8" gap between the siding and the siding block all the way around it or the siding will have no room to move.
I use my ossilating saw to cut it out, a pair of heavy duty snips will also work.
Anyone else notice one of those flush mount siding blocks was being installed wrong that someone posted a picture of? Someone drilled a hole in the center of the lap instead of right at the lap.
