Installing a basement subfloor around floor drains
46K views 17 replies 12 participants last post by  chandler48
Hi All,
This is my first post. I am finishing my basement and am in the process of putting in my subfloor.
My basement is a level concrete slab with cinder block walls.
I do not have any moisture problems, but am installing a moisture barrier anyways.
On the walls, I first put Drylock.
On the floor I put down 1/2" rigid foam with a 1/4" gap on all sides. I filled the 1/4" perimeter with "Great Stuff" expanding foam. I tuck taped all of the joints and laid them off center.
On top of that I am laying 3/4" treated OSB (nailed down with powder driven masonry nails).
On top of the OSB I am going to be installing vinyl tiles. This part of the basement will be where my wife does laundry.
I have 2 floor drains in the concrete. Both are 4" black PVC pipe. One is used to drain from my HVAC/water heater. Another is not used for anything. (pictures attached).
My questions are:
1. For the drain used by by my HVAC/water heater, is it OK to simply cut out a square in the subfloor for access, or do I have to raise it so the top is flush with the new tile floor?
2. The drain that is not used - can I just cover over it with my subfloor? Do I need to do something special to plug it?
There is water in the bottom, but I do not plan on using it for anything. If I can't cover it, how can I raise it up and make it level with the tiles?
I also have a standpipe where my laundry and tub drains into.
I'd like to avoid calling a plumber.
Thanks much!
--Michael
#4 · (Edited)
I sure hope you meant a subfloor that's T & G like Advantec not just reguler square edged OSB.
Your also missing a step, You should not attach glued down tiles to OSB There needs to be a layer of 1/4 underlaymant sanded plywood layed so the seams do not line up with the seams below, attached every 4" on the edges and every 6 to 8" in the field.
Then fill in all the seams and flaws with nongypsom floor leveler or the flaws will show through the tiles.
#5 ·
Hi All,
My questions are:
Thanks much!
--Michael
[/QUOTE
So apparently nobody has an answer. that sucks. I'm in the same boat and the internet is seriously silent on this subject.
#6 ·
I know it is an 8 year old thread, but since you breathed life back into it, I don't see the need in a subfloor on concrete. What would the purpose be? If the concrete floor is flat and smooth, install your floor covering directly over it. I would not recommend carpet, but a product like LifeProof LVP. Tile is hard and cold, but it is an option, too. LifeProof comes with its own underlayment attached, so it is a one time shot.
