I would like to use a stone patterned porcelain tile on a wall of my house outside, south facing. I live in MO so have 100F summer, and -10 winter w snow ect. I have oak boards that run diagonally across the studs instead of the sheeting that is used nowadays. I am planning on keeping that. Then there is a layer of tar paper (I think that is what it is called) and asbestos shingles. I am removing the shingles and putting on a layer of 1/2-3/4 inch beaded foam. This because the house is not insulated well. (old house) Next, I don't know ? I think a layer of plywood or concrete board? A moisture barrier if it is plywood? and then a metal lath, mortar 1/2in thick. Do I allow that to dry? Some sites have said to let it dry and then do the tile, others say put the tile onto while this is wet? I think you are supposed to rough the surface but some videos I watched left it smooth. If I use concrete board, do I need to do the lath at all? (can I use hardie cement siding?) and do I need the moisture barrier? I would love to put up concrete board/siding, and skip the moisture barrier there and the lath step... But I understand that is required for plywood. Just don't know what I need to do. I thought since it is tile and not the really heavy stone veneer that I would not need to use lath. It is about 16x24 size pieces and it is an exterior tile. The house is just one story. The wall is about 16 ft long and I plan to do it up the where the gable starts (9ft?) and then use vinyl shakes. Advice is appreciated. I really need to hear from someone that knows what they are doing. Everything is so contradictory when I try to look it up.
