How to obtain lime mortar for repointing in Ontario Canada
31K views 29 replies 10 participants last post by  ClarenceBauer
Hey Vandertree,
Lots of confusion for me on Lime, Hydrated Lime, Hydraulic Lime, etc. From what I've been able to determine - Hydraulic Lime is what would be needed - mixed with sand in a ration of 1 part Hydraulic Lime to 2 parts sand.
Historic Building Products (Historic-Building-Products-Ltd.) in Toronto is the place to go if you want to attempt this yourself. I spoke to them on Monday and they were extremely helpful and knowledgable.
Another alternative is to purchase Type-O mortar.
Home Depot carries this in 2kg pails and is called "Sakrete Mason-Craft". It can't be stored in bags due to the lime content. This should be completely fine given the extremely low compressive strength (350PSI).
Personally, I went with the Sakrete Mason-Craft as the directions are very straight forward (there's even a youtube video) and I didn't want to make a mistake with the mix ratio, including the amount of water to add - this needs to be exact for Lime mortars.
It's a bit more expensive ($11.99 per pail) but for my application I only needed 3 pails. So it was fine.
Best of luck.
See if you can locate a copy of this booklet.
