how to fill big pot holes in alley?
2.2K views 15 replies 12 participants last post by  tung256
#1 · (Edited)
i have these 2 large potholes. the largest is 8 inches gap in height. the other is not too bad at 6 inches. cars cant just drive around the gap. i know the gaps look small here but they are much bigger in life.
City said it's not their job to fix alleys.
is there anything i can do to make the gap more gradual? a lot of cars go through the alley since our cars are parked on either side of alley. i dont need to fill up the whole hole to make it nice n pretty.
#5 ·
If the public uses it, it is the city's duty to maintain it.
And if not city property, you have the right to shut it off to public access.
Thus preventing the "racers" from tearing that up.
Repairs can be Asphalt patch in a bag, or stones, or concreted.
ED
Reactions: Notmyfirstrodeo
#15 ·
I used to have such a problem, but more & often larger holes. My fix was cold patch asphalt. It would last for years. Cold patch comes in bags at home centers & hardware stores.
Get as much water & loose stuff out of the hole as is practical, but it can be damp.
Dump the bag in the hole.
Next:
Use either a steel hand tamper of make a tamper out of a piece of plywood screwed to the end of a 2 x 4.
If it's hot out, getting the tamper wet helps keep the product from sticking. (If it's hot out, when you dump the stuff it sounds like Rice Crispies.)
Or, you can dump it in, lay heavy cardboard over it and drive back & forth. The cardboard would stay stuck until it wore off from rain or snow plowing. The "run it over method" is quick & easy, but not the "right way". Here's a link to the right way: Repairing Potholes | U.S. Cold Patch
Paul
#16 ·
Next:
Paul
i will try this method if the city still refuses to take care of it. thanks!
