How to dispose of unused thin set, grout, etc?
2.7K views 21 replies 16 participants last post by  Old Thomas
I had some work done on the house and I now have a mostly full 50lb bag of thin set and another of grout. How can I dispose of these?
I live in a "manicured" neighborhood and yard with no place to just dump it. If I put the bags in the trash can, they'll increase the weight such that they might not even get picked up. Also I'm concerned about where they will eventually pop open. In the trash truck as they empty my can? In the building where they sort out cans, plastic, paper, etc? Or all the way to the land fill?
I don't think I can just soak the bags to solidify the material throughout, plus I'd still have the weight issue.
What would you do?
#6 ·
Get some plastic bottles and mix the grout and fill the bottles.
When they harden, cut away the bottle and paint the concrete....all different colors.
Give them away as lawn art in your "manicured" neighborhood.
Reactions: HotRodx10 and Domo
#7 ·
Spread out the thinset and grout on a large piece of cardboard (pizza boxes work well) in a thin layer. Let it dry completely. This can take a few days depending on the weather. Once solid, break the cardboard into smaller pieces and place them in your trash bin. Be sure the weight doesn't exceed your trash collection limit.
#8 ·
I would just scoop or pour some from the 50lb bag into a heavy duty contractor garbage bag, and toss it in with the rest of your garbage. Every time you take the trash to the curb, dispose of a little more. You could even do it over the course of several weeks if you're worried about weight.
Or as someone else said, Craigslist or OfferUp because someone will take it.
#9 ·
How is trash collection done? Down here it's all contracted out to various companies and they use big trucks with robotic arms to load and empty the carts. No issue with picking up a cart containing a bag of grout or thinset. I would lay it down outside and gently wet all around with a garden hose and let it harden up the outer shell before adding the bags into the trash though.
Check your city's sanitary guide though. Do they accept this in the household trash? We have yard waste, mixed recycle and household garbage in separate carts. One is not supposed to put construction debris into household trash, like you can't throw into trash a torn down fence section even if cut up into pieces but I do occasionally dump in end cuts of 2Xs.
#13 ·
Drive around a bit box home improvement store and look for a contractors pickup truck that has a load of "stuff" in it.
Either ask the guy in the truck if he wants it....or wait until he goes inside and set it in the back of the truck.
You can put a nice note on it if you like.
Reactions: KRV4Lee
#22 ·
I dump it in a woodchuck hole. In your situation, I would dispose of a little in each trash pickup.
Reactions: KRV4Lee
