How are modular homes connected to the sill plate?
22K views 15 replies 5 participants last post by  mikegp
I'm looking at pictures of modular homes I have taken on my block and the ones built recently have outer metal straps that connect the sill plate to the house. The sill plate is bolted to the foundation. When I look at the pictures during construction of the houses built right next door about 5 years ago I see no external connection. What other methods are used? Thanks.
One way I've seen it done is with these.
http://www.strongtie.com/products/connectors/LSTHD-STHD.asp?source=holdttcat#gallery
A few years ago we had a tornado touch down near here.
It took a modular home right off the foundation and set it on the ground completely off the foundation intact a few feet behind it sitting flat on the ground.
It never even broke a window or hurt the shingles or the vinyl siding.
Right behind it was a 50' long garage. All that was left was a slab. The whole building and everything it disappeared.
Tools, boat and trailer ECT. gone.
#4 ·
#7 ·
That's how I assumed these were made until I started looking into it further. The sill plate was already on the foundation and bolted down before the houses were delivered. So they must have connected the plates to the bottom of the house somehow or just left them unattached. I can't see how that could have made it passed the local inspectors for four houses. :huh:
#8 ·
#9 ·
Gary, I'm looking at those, but they're not very clear to me. I see no ties or attachment plates of any kind. I imagine I would see a lag bolt or any big bolts. So I'm thinking they were just screwed, but where would the screws be? Diagonal through the rim joist into the sill? That doesn't sound strong enough. I appreciate the help.
#10 · (Edited)
Yes, they all pass code minimums. A normal stick framed floor has solid (or engineered) wood joists that are toe-nailed to the sill plate (which is bolted/nut/3"square washer- around here for seismic) and rim joist also toe-nailed; #23, 26; http://publicecodes.cyberregs.com/icod/irc/2009/icod_irc_2009_6_par013.htm?bu2=undefined
Page 9- "Floor Framing"
and pp. 24-- Fig.11; http://www.awc.org/pdf/WCD1-300.pdf
They leave the bottom rows of siding off to toe-nail, then add them- "Sill plate"; http://books.google.com/books?id=Kp...Q6AEwCTgU#v=onepage&q=attach new modular house to foundation sill plate&f=false
Gary
#12 ·
You should see/feel some toe-nail ends of fasteners through the sides of the joists running perpendicular to the sill plate. The rims are fastened on the exterior, can't see those unless you are superman- or an alien that got your superpowers 25 years (and a 1/2 day) faster than superman from same planet.... lol.
Gary
#14 ·
Perhaps the engineering page shows the detail of attachment, as it has been approved to meeting minimum code.
Gary
#15 ·
Not sure if your still interested. I had a mod installed on a superior wall basement in ny in 2014. The sill plate attached to the superior walls through carriage bolts. Then every 2 foot I believe is the distance was metal strips they go across the width of the sill plate I think they are 12 inches could be longer. After the house is dropped the metal strips are bent up and attached to the mod rim joist. That's why mods are missing the bottom two rows of siding when they are dropped. The strips prevent the house from being pushed in the wind and the weight keeps it on the foundation. That's why mods can be separated and moved by certain companies if they are 2 pieces. In high wind areas there are a few other things that have to be done to attach it to the foundation but the majority of the country that is how they are done unless there is higher building codes the international code.
Hope that helps. Also I saw the comment on the house being picked up and dropped. Some of the builders of mods tell you about the safety of them. As they are built to be moved and go down the highway at 55 without falling apart so whey are sometimes considered stronger then traditional homes for that reason.
#16 ·
I mentioned in the first post that the new houses on my block were using straps, but the old houses didn't. That's what made me question the whole thing. I'm thinking they may have used OSB that spanned from the sill plates that were bolted to the foundation to the rim joist. The sheathing on the house didn't go all the way down which left room to attach a strip of OSB. Don't know if that would be sufficient.
