Down streaming just means you are adding the chemicals after the pump. This extends the life of the pump, but limits your chemical ratio - a lot of water has to go through to siphon up a little chemical. It's good enough for siding, but you can't wash a roof like that. Temperature is a separate issue. A few guys use hot water on houses, but it's mostly used on really greasy, disgusing stuff like gas stations and dumpster pads.
