Had a general contractor install a 300ft. vinyl fence on my sloped-incline backyard. We were left with a huge 12-inch gap at the bottom of two sides after the contractor attempted to make sightline at the front of the fence appear to be all one height even though it sloped slightly downward. How can this be fixed?
Its left us with this big gaping hole under our fencing on two sides and with two small dogs, its been a challenge trying to keep it blocked off while we come up with a permanent solution.
Any ideas on best practices to fix this? the double gate on the same wall is also installed so tightly that it is a struggle to open and close...see attached pictures of gap on two sides. General contractor is no longer involved, so need suggestions on how to repair so there is no more gap ( or at least a normal-sized gap).
A different fence contractor, not involved with the install, said all the posts were "dry-packed" in case that impacts any options on repairing...at a loss of where to begin. Any good ideas on a permanent fix?
