Hi -
Can someone help me with ideas to remedy an improper hardwood installation. I have a lot (1500 sq ft) of new 3/4" hardwood that has been installed in my ranch house. However, it turns out the subfloor is only 9/16 OSB instead of the recommended 3/4" minimum. Now, after only two months it seems many of the boards are popping up at the edges. I'm assuming this might be because the subfloor is too thin to hold the staples properly and/or flexing in the subfloor might be making it worse.
I really don't want to tear up the entire floor in order to lay more subfloor. Any ideas?
(I have an unfinished basement, so it might be possible to add cross blocks between the joists to help strenghten the floor)
Also, would it be a good idea to use crews from below (up through the subfloor and into the offending boards) to help keep the boards down.
Thanks!
Thanks!
