Hello to all
Had a contractor come back to patch up and set tile where he cut out to fix burst CPVC line.
this guy did the original work of redoing bathroom and setting & grouting tile.
he had some workers come over and do the work while he first cut the tile, then he left
i was outside working and when i came in to check the job, they had left. The pic w the description shows there’s nothing behind where the grout line would go. Before it was solid backer board from top of tub line to ceiling. If you put grout in it, it would just keep falling to the ground, There’s no way to pack it. So, i pulled out the tile and the backer.
the last few pics shows where I can stick a DW40 red spray extension nozzle into the grout lines full length horizontally and above 1.5” verticality down.
Comments?
Thank you for your feedback.
Comments?
