A bit off target (tried appliance section but not much satisfaction).
In-law's GE ca5dmb freezer stopped working.
Compressor kicks on for 5-10 seconds then shuts off no matter thermostat setting.
I tested the leads from the compressor to compressor housing and got no continuity (not internally shorted).
I think it is one of two "relays" that plug into the compressor (each has a single wire going to them).
I think the top one is an overheat one (that had continuity when disconnected from compressor after it kicked off and before it did so so I don't think it is that).
The bottom "relay" has two terminals that plug into lugs from the compressor and I'm guessing it is a start capacitor?
It had continuity but I've no capacitor tester.
Appliance section recommended: "You can get whats called a three in one put in place of yor relay and overload to see if its going to run but I would not leave it if it runs replace your componets and off you go.
http://www.globalindustrial.com/p/hv...-14-13-hp-230v"
and
"get the RCO810 3 in 1 "
My question (not answered and in-law is pestering me (no good deed goes unpunished!)):
If I put in the URCO810 (same as RC0810?) is it ok to leave it if it works?
I'm more worried about a fire than anything else.
I read elsewhere that hard start kits shorten life of compressors?
Thanks for any insights,
Bob
and
Bob
