I have burned up 3 120v HF wire feed welders, pushed them until they melted.
I have a 14" HF chop saw going on 35 years, just used it to cut all the steel studs for my new home. All the structure parts were done by the erectors.
Got a 7.5" skill saw that I use when I need to, the motor bearings scream during start up and shut down, still works after 30 years.
When I was working and traveling for work south of the border I would always spend about $100 bucks for a hand tool set which I left on site. Huge good will with customers.
I had to remove the stabs on a transformer lots of 11/16 and 13/16 bolts and nuts.
I bought a dark colored wrench set. All of the other tools broke, the HF wrenches are still in my tool cart but the dark color came off the two widely used wrenches.
As long as your expectations are not over the moon and you do not expect 0.004 accuracy, they are good to go.
The hand tools, screwdrivers and such, yes the tips are a lower grade than what I use for work, (electrician). Water pump pliers, a bit loose compared to brands that are double the cost. Pipe wrenches work great as long as you lube them.
I still go to HF and buy stuff. I have never owned a battery tool from HF.
I do have 2 of their 4" hand grinders, Two different kinds of wheels on them. I hate changing wheels when I am working on steel.
I purchased a Hobart 210 MVP as a welder and it is all that I need.
