Hi i have used a few of these foam spray's
but after i use just some of it, the straw and tip gets loaded with hard foam and gets blocked.
i wanted to know...
is it possible to reuse these cans?
How do i clean out the straw or make sure that the straw doesnt get clogged with foam after using it?
Once the straws are loaded with hard foam, is it possible to clear it out?
how do you prevent it from getting clogged?
Are there some good reusable straws out there in the market that helps with this kind of issue?
or are these cans a one time quick use? If you only use a little, then the whole can is worthless?
i wanted to know...
