grading/compacting dirt question
3.9K views 5 replies 3 participants last post by  Daniel Holzman
My residential backyard is approx 75' wide x 20' from back of house to backyard wall. Jack hammered old concrete patio out,tore up old lawn, yard had to much dirt in it and not level. I removed a lot of dirt.
I now have yellow strings tied to 18" pieces of upright rebar pounded into the dirt close to the back of the house stretching to another piece of upright rebar 20' away at the footing of the wall. The string is an inch higher at my house than at the wall for slope. I have spaced the strings every 3' across width of the yard so I have a way to level the dirt. I am certain I need to use something to compact the dirt.
Eventually I will have a contractor come in and build me a patio cover, pour a concrete patio etc,... We are doing the grunt work and letting a professional build the finished product.
Is a plate compactor the best way to go for compacting the dirt? Any thoughts?
I dont have a basement so that is not an issue. I actually found a 10" x 10" hand tamper sold by home depot for $40 weighing 13 lbs and decided to try it. I understand what your saying about tamping 2-3" at a time but the dirt is already in place so I am just going to have to tamp it the way it is an hope for the best.
#4 ·
If you plan to place a concrete slab over the soil, you are going to want the correct soil in place. Proper soil to support a slab is well graded sand and gravel, with a limited amount of silt allowed, but no organic soil, and no clay. Of course people build over improper soil all the time, but the result can be cracking of the slab, settlement, or heaving if you are in frost country. Since you have gone to so much trouble to prep the site, it would be unfortunate if you tamped poor quality soil, later put a slab on it, and the slab performed poorly.
#6 ·
Your building inspector should be able to help you out. Since you are in southern California, probably no frost. Typically you would need to remove all the organic soil (too compressible to support a slab), then place around 6 inches of crushed stone, maybe a little less if the natural soil is sandy or gravelly.
