Hope this is the right forum, has anyone had experience mounting grab bars in a fiberglass shower, problem is the shower is contoured and the drywall/ studs are about 3” behind the shower wall surface.
You are right they waste room but are a cheap option when money is tight.Remove the fiberglass shell. Imo installing a fiberglass shell was the first mistake. Fiberglass shells waste room and adds to claustrophobic feel.
Then put up back boards where you want grab bars. Then cover the walls with solid material that is Corian type or manufactured marble.
There. Problem solved! Thank you.
I did read the OP's post and there are 2 solutions that IMHO You can open the back wall up and put blocking in or buy The Solid Mount on Amazon and do the modifications from the manufacturer's website for spaces up to 3".Did you bother to read the op? It is a contoured fg stall that sits 3" off the studs and drywall behind it. While I would agree that it is not as secure as a bar fastened directly to studs, that is not always an option.
Fiberglass shells are lousy imo and OP question points out why they shouldn't be used. Space is valuable. And the shower is a very important space that people use every day.You are right they waste room but are a cheap option when money is tight.
Fiberglass enclosures virtually never utilize all the space available when used as retrofit. They are claustrophobic imo.Fiberglass or acrylic units are economical, quick to install and very easy to take care of. They rarely develop hidden leaks that rot out your house. I tore out more than a few of the old tubs or showers that had laminate, hardboard or plastic surrounds. Always had leaks and hidden damage. Nasty looking caulking and sealants all over trying to keep them sealed up.
I ripped one of those out of our house right after we moved in almost 30 years ago. Installed a fiberglass tub/shower that's large and spacious, used every day and it still looks brand new. No leaks, ugly caulking, mold or mildew. It's easy enough to install blocking and grab bars during install of the unit, if you have the forethought to do it. It's not the fault of the product if the installer failed to do it.
