Are the disposable 3M type masks ok for doing this or should I have something with cartridges?
Thank you for any suggestions
Thank you very much! I can definitely pick up a 12” knife and give that technique a try. Not planning nothing fancy on texture but I’m curious on what you’re thinking for sure.So far, so good, eh?
Pics don't always tell the entire story.
Examining them as closely as I can......
Not many fasteners in the ceiling.... screws should be about 9" apart.
Areas of solid, not feathered mud lines... those lines may cause difficulty with final coat.
Finish mud with a 12" knife... feather joints to nothing at apprx. 12" each side of joint.
Take your time; it will be worthwhile.
Will you texture the ceiling/walls? texture will camouflage some flaws.
Hang in there. You're doing fine.
Thank you very much wonderful help!@phillipd
Next step.... Sanding.
Suggest this tool. It will take a few minutes practice use but will save time and effort.
While I can't see your finished mud, consider using sanding screen. or 120 grit and finer paper.
Avoid scuffing the drywall paper. be gentle.
Do not use heavy pressure; let the tool and screen do the work.... take your time.
156
3-3/8 in. x 9-3/8 in. Swivel Head Drywall Pole Sander with 48 in. Wood Handle
by
ToolPro
(Brand Rating: 4.3/5)
- Feature thumbscrews for use with multiple sheets
- Swivel head allows for ease of movement for comfortable use
- Made of high-grade materials for enhanced durability
Thank you very much! This area is upstairs of our garage just outside the stairway door is drywall that was professionally done and was only finished with primer (I thought it was paint they did so well) once you get downstairs it’s white steel walls and drywall ceiling painted white. I definitely want it to look as good as I possibly can but doesn’t need to be perfect. The end use will probably be a mix between storage and workshop. I have 2 leftover sheets of drywall for practicing on. I’ll post a few pictures of the stairway in a bit!@phillipd
Great!
Don't worry about the errors, sometimes they happen to Pros; It's part of your learning curve;
You're doing fine.
The goal is to eliminate the "DIY done" factor and with patience, you're doing it.
Part of that means, as the applicator you may notice some finish flaws but they will not stand out to others unless you, personally, mention them.
After you complete sanding, you check for flatness of the wall. It will not be perfect but must be near enough to not exhibit waves ( the reason for wider feathering from joints ). I am assuming you are not going to "float" / "skim" the entirety of drywall.
While progressing that direction....
if texture is applied, you want it to closely match the rest of the house.
It would be good to have a 2-3 sf pic of the existing wall/ceil texture.
Oh, you 'll need a sheet of drywall to practice the texture application before you start the walls. A couple of half sheets can work.
Be patient with yourself; you're going great! enjoy the learning.
It won't be long before you'll be on this forum sharing your adventure with others attempting what you are doing. Enjoy the learning. !![]()
You're closing in on paint prep.. nearer to the finish.
Thank you both for the wonderful tips! If you ever have any electrical questions please don’t be scared to ask! Ok adding up the sheets of drywall I’m looking at 1000-1100 square feet of surface area, what would you recommend I pick up for volume to start ?
Thank you very much! I think painting the floor up there’s going to be next !WOW!
Great work!
No visible waves in the wall; joints look good and paint appears even.
Bask in your success. Enjoy your adventure.
Remember, you are your own nastiest critic. If you see flaws, don't point them out to anyone when you are complimented. Accept the acknowledgement of your fine work.
Also, you've given us (forum members) a bit of vicarious satisfaction by accepting our assistance.
You did yourself proud; stand tall in your accomplishment.
Now that your near completion, what's your next project?
We're here.
Hope you enjoyed your adventure.
CONGRATULATIONS!!!
Definitely and thank you! I may be building/installing commercial shelving in there this fall@phillipd
CONGRATULATIONS !
Your adventure was well worth the efforts.
Looks Terrific !
Vicariously, we also get the satisfaction of accomplishment,
What next can we give help ?
after thought:
People seem to have a need for floor coatings. It will be nice to get a durability evaluation on that Brand after about a year or sooner if it deteriorates.
