Deleted and reposted this from different subforum.
Hi Everyone,
Long time lurker, first time poster. Have a question about laying glass tiles on a kitchen wall.
Soon installing glass tile backsplash with 2x6 tiles that are on a mosaic sheet (6 rows of 2 tiles offset 50%) that were picked up from a big box stores. Tiles are 1/4 thick and have a backing on them that gives a white color.
Tile manufacturer recommends white modified thinset, so plan to use Mapei Adeslex P10. My concern is whether to proceed as the wall has been currently prepared (next paragraph), or to take am extra step of applying a tile primer like Mapei Eco Prim Grip.
Wall is 15 years old, been painted several times with latex paint, and recently went through some cabinet and trim replacement. Used some spackling to fix up the wall and then sanded with 80 grit, and put on two coats of Bullseye 123 primer to coat the old paint and spackling.
My plan was to scuff the Bullseye with some 60 or 80 grit, and then tile with the recommended adhesive. Should I;
A) Proceed with my plan of scuffing the primer and using the modified thinset.
B) Apply a tile primer (Mapei Eco Prim for example).
Thanks in advance. I've tiled with ceramic before but want to get this right.
Andrew
Hi Everyone,
Andrew
