Gas Furnace Flashes- 3 times- AS Freedom 90
2 reading
7.9K views 2 replies 3 participants last post by  MRad
I have an american Standard Freedom 90 Gas Furnace that does not light. There is a flashing light on the control board that is flashing 3 times. The thermostat is calling for heat. The code for 3 flashes says pressure switch error. What trips the pressure switch? I found what i believe to be the switch ( micro switch attached to a small diaphragm ) with clear hose attached. What do I look for in troubleshooting the problem. Thanks in advance for your help.
Was receiving the 3-flash Error Code. From the info on several posts, I just removed the clear plastic hose from the pressure switch, cleaned the end a little, made sure nothing was in there. Placed it back onto the pressure switch and furnace started right up. Thanks!
