Maytag, probably 13 years old.
The water dispenser is very slow. It takes 40 seconds to dispense two measured cups of water. I had replaced the filter about 5 months ago, but I put another one in, just in case. Didn't help.
In addition, the ice maker has been acting strange. It's not making complete cubes. Many of the ice cubes are empty, with just a shell on the outside. I disconnected the ice maker water feed and measured a fill cycle. The Dispenser Operation sheet says we could get about 4.75 ounces in 7.5 seconds. We only got half that much water. I didn't time it, but I don't think the ice maker supply ran 7.5 seconds. It seemed like less. A Google search says you get hollow ice cubes if the pressure isn't high enough. I will try and time the fill cycle later.
I replaced the ice maker assembly with a new one four or five years ago because it was corroded and not ejecting the ice.
I checked the water supply at the intake valve and there is tons of pressure available.
What are your suggestions?
