Forms for curved concrete
50K views 12 replies 5 participants last post by  stadry
Wondering what you guys use for a strong flexible form. I plan on pouring a landscape curb around the back yard in the next month or two. Total length is going to be about 150-200 feet, 6 inches wide and 4 to 5 inches high and I only want to pour 25-30 feet per day so whatever I use needs to be strong and reuseable. The smallest radius is only 20 feet so the bend doesn't need to be that sharp. I looked at landscape edging but it doesn't seem strong enough to hold a smooth curve. The other option I was thinking was some Trex decking. Thanks.
whatever bends w/o breaking - 1 x 4's, masonite stripe, reuseable plastic ( eBay ) - don't forget stakes to hold the forms in place :thumbsup:
for landscape curbing, you may want to score contraction jnts on a regular length otherwise the conc'll crack on its own,,, scored jnts look much better :)
#5 ·
#6 ·
Get yourself some 1/8 inch steel by 6 inch high by any length you find at a re-cycle yard.
Have tabs welded on one side of it to drive stakes through, about every 3-4 feet apart.
1/2 inch re-bar in 18 inch lengths is great for staking.
Use form release oil on the face to get it to be released easy.
Very durable, and will flex for most curved areas. And can be re-used again and again, then re-cycled after you are done.
ED
#8 · (Edited)
Markets differ greatly from region to region, flyer posts from Aridzona, not Illinois.
And the recycling centers here in Wyoming are different from both. The one here will sell you a 4 x 12 foot sheet, and only charge a $1, per cut to shear it into 6 inch pieces.
I recently bought a 4x8 x 1/2 inch thick sheet for around $125.00.
I agree that the cost might be more than someone wants to pay, but the probability of getting the results they want with Masonite, MDF, or other water absorbers is so poor that I prefer to "DO IT RIGHT THE FIRST TIME".
Many high schools have a welding class, the work is free if you supply the materials.
And many people have their own welding equipment, or access to friends that do.
It was just a suggestion, and I am not trying to start a war over something as trivial as an opinion.
ED
#9 ·
Why would you think I was trying to "start a war" by offering my opinion?I suggested Masonite and not MDF.I and many other pros have used Masonite for curved forms for many years having successful results.I recommended against mdf.
You're suggestion of "DO IT RIGHT THE FIRST TIME." suggests that you're way is the only way and is definetly not.
#10 ·
We have a few sets of commercially made plastic forms with slide in wedge pockets, but for the odd situations that we need something else, we often use hardboard siding, which comes in 16' length, 12' high, 1/2" thick. We just rip it down to the height we need. For shorter, tighter radiuses, 1/8" or 1/4" Masonite will work better..............
#12 ·
Went looking today and found what I think will work well. Fiber cement lap siding in 12 foot lengths. It's about 3/8" thick, bends easily to a 20' radius (any more and it might snap) and the curve is smooth and strong so it won't require a ton of stakes. Only problem is it's 8" tall so it will need to be ripped down to a usable height. Best part is it's only about 9 bucks.
