Fix for long metal tube farm gate ?
1.6K views 11 replies 8 participants last post by  notnew2diy
Metal tube gate that spans about 18 ft across cattle guard
Good solid post that is and doesn’t move
It sags so much one has to lift it up a good bit to open/close across the guard
One suggestion offered is to afix a taller post. Run a wire and turnbuckle from high up on the post to the gates far top end
Question- how would one affix the post side of the wire ? I assume it would need to rotate as the gate moves ?
A wire from the post side gate top across to the far side bottom might offer enough support eh ? Not much of an angle for such a long span it would seem
An 18' gate is a long one. Is the gate itself actually deforming? Is the post dead nuts plumb - any out-of-plumb is going to be really apparent at 18'. Is the ground under the gate level?
If you want to go the support cable route an eyelet ring should suffice. If I had to, I would use a welded ring rather than just a bent one. Obviously the taller you go the better the angle.
You could also install a gate caster.
#5 · (Edited)
I will assume, 18' gate has at least 1 vertical support brace.
Wrap a chain around one of the horizontal steel, far side of the vertical support. Use a clevis to connect, making a loop of sorts. Kinda like Greg's picture.
Steel cable from clevis to a stout turn buckle.
Prop up end of gate w/a piece of wood, a rock, etc.
How you attach it to your post kinda all depends.
I've screwed a 2x6 to the far side of the post that was 2' taller than the post.
Drilled a hole for a thru eye bolt, nuts and washers on both sides of 2x.
Use another clevis to connect turnbuckle to eye bolt.
I've strapped a piece of 1" black pipe to far side of post.
Drilled hole, clevis, as above.
Gate is not all that heavy, relatively speaking, its the leverage.
HTH...Good luck...Don.
#8 ·
Don't think I have ever seen a farm gate that was close enough to the ground to keep the critters in that did not sag and drag. I doubt that a tension bar is going to pull it up.
Mark's wheel is the best suggestion. They sell them at the farm supply stores.
#9 ·
Why would I want my gate to drag the ground if I had llamas?
Mini-donkeys? Mini-horse? Regular size horse? Cattle or cows?
I'll give ya, goats were a problem to keep inside an enclosure.
They would shimmy under a gate that was not close, or if the fencing needed work.
YMMV...Don.
#10 ·
What OP proposes is an option; although not that common in areas I'm familiar with. It is simply an external diagonal brace as opposed to an 'internal' one that braces the diagonal corner of the gate itself.
If the hinge post is plumb and doesn't flex when the gate is swung, another option is two shorter gate panels joined by a chain.
I think the widest gate we had was 14'. We didn't really have any great problems with it but I purposely installed an 8' gate to move the critters and left the big one for just tractor access.
#11 ·
From the OP, " Metal tube gate that spans about 18 ft across cattle guard "
It just hit me. Why does anyone need a swinging gate, when they have a buried "cattle guard"? Has the cattle guard been allowed to clog solid with debris to the point, the livestock can just walk over it maybe?
