If you have a problem with your Famowood Glaze Coat remaining sticky after applying and curing for 48 hrs, pour peroxide over the entire surface and let dry for 30 minutes. I used this product on mosaic trivets that I made and had to pour more than the recommended thickness of 1/16". When it remained sticky, I called the company and they recommended using a lint free cloth and acetone then pouring a very thin coat on top of the sticky surface. This did not work. I tried the peroxide and it worked great!!! And alot less expensive!!
