A lot of people have been telling me that when installing insulation it is necessary to leave a bit of an air gap between your outer wall and your insulation in order to allow for air flow. How much of a gap has never really been specified, which is also confusing because I understood that bat insulation was sized to fit the entire 3.5 inch depth of your standard studded wall.
If it is true that this space is needed, then why is it no longer the case when installing rigid or spray foam, as presumably these would be applied directly to the wall leaving no space at all? Is it because these materials are moisture resistant so the space is no longer needed?
What is your opinion?
I'm about to install a bunch of bat insulation and I'd prefer to not f*** it up too much. Should I be trying to "pull it out a bit" so an air space remains at the back? Would it be terrible if there was an air space at the front under the drywall?
Thanks for all your advice
