I am staining my house, but need to re-caulk sine I replaced lots of clapboard and trim. I plan to use Benjamin Moore Arborcoat solid stain.
BUT DAP says stain does not adhere to caulking. And if I stain first and then caulk with a clear caulking, then I run into the same problem when I go to re-stain the house in 5 - 7 years, i.e. the stain will not adhere to the caulk and/or the solvents in the stain make have a negative effect on the caulk.
Certainly this has to be a common problem.
What have others done relative to caulking and staining (solid stain)?
thanks
thanks
