exterior finish work
3.1K views 3 replies 2 participants last post by  AAPaint
What kind of filler should one use for filling gaps in trim boards etc on the exterior of a home? Inside, I just use wood putty and/or painters caulking.
Are those acceptable for working outside too?
They are if you're using quality fillers. The trick is to use it sparingly first of all, and to make sure you prime any areas you plan on filling. If the wood is soft and mushy, forget it. It needs replaced. Don't caulk gaps larger than 1/4". Anything larger needs a backer, and I'd recommend vulcum for those areas. I use 1100A siliconized latex from SW that has a 55 year warranty. For wood fillers, there are many choices...the important part is that you prime, fill, and prime again. If you don't protect the filler or the filled areas, and give it something to stick to it will fail. Also, filling nail holes is a whole different story from filling large holes on rotten wood.
If you're talking rotten wood though, you really should replace it, find the source of the rot and remedy it while the wood is removed. Back prime anything you replace by priming the entire piece of wood, front-back-end grain.
Hope that helps.
