Hi;
I am going to install an amateur radio/scanner antenna. This antenna is fairly small and light, being constructed from 1/2" copper pipe and is about 60" long.
I want to use a 10 ft mast, and thinking that 1-1/4" or maybe 1-1/2" EMT would do. It's a lot less expensive and I think a much better conductor of electricity (for grounding) than the painted steel mast sold at Radio Shack, and I wouldn't have to scrape the enamel from the pipe before attaching the ground clamp.
Do you think that EMT would withstand the wind loading caused by this small antenna? I estimate wind loading to be very low, considering that this is basically a single element vertical antenna with no ground plane radials.
I live in New Jersey, where we don't see many really bad storms, and I can remove the whole assembly in the event we do get a TS or hurricane.
Thanks
FW
Thanks
FW
