1725 rpm as recommended. I would like to connect a foot pedal as well? Does that call for a specific type of motor as well?
No. You can use a foot pedal with any motor. However, to not confuse you anymore than you already are, its basically a switch that you operate with your foot.
Google foot pedal to see whats available.
I wish I had seen this thread sooner as I would have suggested a PM DC motor with a small DC controller.
This way you get built in speed control and only need a cord and plug for the controller. They can run on 120 or 240 volt ac.
Small PM DC motors are inexpensive and the controllers are as well.
You cannot run that wheel at 1800/1750 RPM. You will sling mud everywhere and I think you have already found this out. The pulleys are there for a reason. To get the proper speed. Old fashioned way. But works well if you only need one speed.
They do make AC variable speed controls, that might work with what you have? They also have a ramp function so the motor can be set to ramp up and down slowly. That's what you need.
Both the DC and AC mini controllers have a speed potentiometer on the front for easy speed adjustment. More money for the enclosed type. They also have "start, stop, jog" switch on them
You can start out at zero speed and adjust until you get the perfect speed.
Hello Everyone, I have finally completed my electric pottery wheel, however my motor is too strong, does anyone know how I should determine what kind of speed controller to add and how to connect it?
Too strong or to fast? The ones below are chassis mount and require a box, potentiometer and a cord and plug. But take the time to look over the manufacturers site to see what else they have.
This is KB's site. There are others and you may find better prices.
Heres the DC drive.
https://motorsandcontrol.com/kb-electronics-8609-kbwd-13-0-130vdc-1-3-hp-chassis-dc-drive/
Heres the AC drive.
https://motorsandcontrol.com/kb-ele...25hp-1-phase-110-120v-200-240v-input-ip-20-enclosure-variable-frequency-drives/
Edit on this one. It outputs 3 phase. Use for example of chassis mount.
I'll look for an ac in, ac out speed control for you.
I did not link you to the models with enclosures and built in speed pot.
Just an example really.
Just so you can see whats available besides mechanical speed intervention as you have now.
Should you decide to stay with what you got you will need to change those pulleys to get a usable speed. Full motor speed is way to fast for your needs. As you most likely know now.
