Electric motor for pottery wheel
15K views 36 replies 10 participants last post by  SeniorSitizen
Hello Everyone,
I am building a pottery wheel and I would like it to be electric. It would Be nice if I could install a foot pedal as well.Ive read and seen I need a ac motor, I purchased one but it is not strong enough to turn the belts(pulley system) can anyone tell me what kind of motor I need to get please. Thank you for your help
#6 ·
No, it's not connected to the wheel itself, I have a pulley system. As shown below. The smaller belt would go around the motor and a smaller pulley I have on top of the motor. I have it as tight as I can get it. So I figure it's either tension or my motor isn't strong enough
#8 ·
What speed is recommended for a pottery wheel?
The wheel RPM can be calculated by motor RPM x drive pulley diameter divided by driven pulley diameter. Other configurations of a jack shaft or mule shaft can further reduce the speed if necessary. The same formula is used to calculate final RPM. Formula = all the drive pulleys divided by all the driven pulleys.
#9 ·
I'm not sure what speed is recommended! Thank you gentlemen for your help! This is a Mommy daughter project!! So your saying on the name plate where it says 1/15 it needs to be the numbers you mentioned and the Rpm shouldn't be more than 1725 correct? I'm totally lost with the formula so I will start with looking for a different motor!! Thanks again guys! I appreciate it
#17 ·
How's, I've purchased that same kind of motor just stronger. My only problem with that is, the wiring, the wires are not exposed from the motor. Just the + and - so I can connect it to an extension cord, and then plug it in to a wall socket. With a treadmill motor, I can connect a on/off switch with speed control from what I've seen. But, I've never done anything like this so I'm a little nervous especially with the electrical stuff. How am I able to control the speed from the first motor?
#20 ·
first you need to find an electronic motor speed control,
you will have to be sure it is suitable for that motor.
The easiest way to do this is to take it to a motor shop.
Then decide on what type of switch you will use.
once you have theses two items sorted.
Now find an approved j box to put them into.
You will also need a cable and plug for the incoming supply.
And also another piece of cable to go from the box to the motor.
You will also need some bushs to protect the cables where they
enter the j box. The types and sizes of the cables will be dictated
by local electrical codes, ditto with the bushs, so you should consult
with a local electrician or inspector as they will know the finer details.
:glasses:
#28 ·
Ok, oso954, you were right I connected a single pole fan controller and only "high" works. That's what the electrician suggested, but I see I'm going to have to to find a variable speed controller for this project. How do I determine if the controller is compatible with my motor? Here are the specs of my motor
