I have two questions, one theoretical and one practical:
1. Which is the better or more efficient method of hooking up two
identical water heaters? AND WHY???
2. If I have a parallel piping job on two water heaters and I have to
replace one of them and the new one is taller and has fresh new
heat traps, won't that effect the balance? Should I pipe those in
series?
Series is where the cold water goes into one water heater then through the second water heater.
Parallel is where the cold supply has a tee which feeds each water heater independently and joins them back together to one hot water supply.
THANKS FOR YOUR INPUT!!!!
series?
