Drywall Patch Repair Question
1 reading
2.4K views 9 replies 5 participants last post by  ToolSeeker
Had to move a electrical box. I had set it back a bit far so I took some Henry's Yellow fiberglass mesh as I didn't have drywall tape and laid it on and trowled with One Pass spackle. Looks okay, but wonder if anyone has used that fiberglass for this kind of application. Slightly thicker than drywall tape. Would hate to have to rip it out and do again!
I hate mesh tape too but have stretched across outlet openings a time or two and then used a couple passes of hot mud to finish the patch. It is usually just faster to cut a winged drywall section. There is a name for this I can never remember (California patch maybe?) but you measure the opening carefully and then cut the patch 1.5 or inches larger than the opening all the way around the perimeter. Then slice the drywall off the paper that dimension. Fit the patch in the hole and use the paper wings as if they were drywall tape.
Those metal mesh and fiber patches at the paint store work out better than mesh tape too but you have to feather them in so they do not stand out.
I agree spackle most likely will crack.
#4 ·
I agree spackle most likely will crack.[/QUOTE]
For quick small jobs I really like those patches. They come in 4x4 6x6 and 8x8 and are pretty easy to use.
#8 ·
Why would that be better than opening a package taking out a pre made self sticking patch that you put over the hole and mud, comes already taped, just add mud. No squaring the hole, no measuring, no being careful not to cut all the way thru the paper. Honest I did hot or cali. patches for years these new patches are so much easier and better.
