I have a trane heat pump, about 2 years old, it was the top of their line then. It has been perfect, well except one fault. Which is probably mostly my fault, but i think some fault rest with the hvac installers too.
I had them place the outdoor unit on our carport, which shares the house's concrete slab foundation. This was my first experience with a heat pump, so i didnt know the outdoor unit condensates this much, or at all. The hvac installer failed to inform me of this bit of info as well....i would think they would since its on our carport..... especially since the condensate floods our entire carport, and freezes into a sheet of ice during really cold times, all other times, its just an annoying puddle of water to walk through. Luckily the house is raised up higher than the carport, or it would flood inside probably.
Anyways, my questions are about having a drip pan under the exterior unit and having the condensation drain somewhere else via pipe.
what problems could occur?
does any company make drip pans for them? if they dont, i can easily fabricate one out of steel.
if i did make one, any suggestions on anything particular to do when i design/build it?
if i dont do a pan, i could move the unit over about 6 feet, which will put it off of the slab, however, this is a lot of water (in my opinion, under our situation) to be pouring into the ground and under the house. We live on the side of a hill, with a 10' retaining wall on the opposite side of the hill and exterior heat pump unit.....which doesnt make the water draining under the house, sound good. the indoor condensation drained out on the ground right by where the external heat pump unit is, but due to its abundance of water and flooding the area too, i have temporarily ran it into the septic untill i can get another drain line ran. (which i could drain both of them into when i do get another drain line ran.)
anyways, hope i didnt confuse you. thanks for any help.
