I'm adding a shed dormer and I'm looking for input on whether a top plate is needed when a window header spans the full length of the wall.
The image below describes the framing I'm looking to use. The height of the front dormer wall (measured from the top of the current roof rafters to the bottom of the new dormer rafters) can only be 19" to achieve the proper roof slope. This wall will have a 12" tall window in it, leaving only around ~7" of clearance for framing lumber. I'm using two sistered LVLs as the window header and they will span the full length of the wall. I want to omit the normal 2X4 top plate above the LVL header, since the LVL header is acting as the top plate.
I believe this is allowed in my jurisdiction (2018 ICC) since "R602.3.2 Top Plate" says "Omission of the top plate is permitted over headers where the headers are adequately tied to adjacent wall sections in accordance with Table R602.3.2."
Am I understanding the rule correctly such that I can go forward with my proposed framing?
Thanks for the input and advice.
