Does quikrete need to fully cure before leveling compound?
4.2K views 10 replies 4 participants last post by  chandler48
Like the title says, do I need to wait the full 28 days? This is a 24”x24” (roughly) area around a shower drain that was not filled. The concrete depth will be about 3-4”. How long do I need to wait to pour leveler?
thanks
It depends on the type of leveler. With cement-type levelers, the sooner the better. For plaster-type leveling compound, the concrete would need to be fairly dry, so the leveler will harden. Don't know if you'd need to wait 28 days. No worries about the concrete either way. Sealing concrete up so it stay moist will make it stronger.
#4 ·
I’ll get a picture tomorrow, but I did do my best to level it as I poured. I did at least take a level/straightedge across it to make sure it was the same plane. However, it was not the smoothest of concrete and therefore was not super great for a self leveling effect. Also, there were other parts of the floor that were pretty uneven, but seemed too thin to use the quikrete to level those spots. At most I’d have a quarter inch to fill, and I don’t think the concrete mix would stick to something that thin.
so it should be fine to pour self leveler after the concrete hardens but not fully cures?
and for that matter, I will be using a kerdi shower tray which is pre sloped… does it necessarily matter if the subfloor isn’t perfectly level? Could I just use a thicker layer of thinset to install the kerdi tray and call it good? For what it’s worth, I’m sure that would WORK, but I wanna do what’s right long term too.
thanks for the replies
