What tips have you learned in your DIY experience that you wish you knew earlier? Let's learn from each other and share our tips! To keep this thread going come back each day to share a tip and read the latest posts. :yes:
Water leaking from your toilet tank will not only cost you money when it comes to your utility bill, but it can also cause water damage to your bathroom floor and premature wear of your toilet’s internal workings. To find out whether your toilet tank is leaking, add some red food coloring to the water in the tank. Come back in about an hour and see if the water in the bowl is pink. If it is, you have a leak. http://www.moneycrashers.com/diy-home-maintenance-tips-ideas/
On a Cabinet. Simply remove the small screw and plug the hole with a toothpick dipped in carpenter's glue. Let the glue dry, snap the toothpick flush with the surface, and reinsert the same screw. On a Door. Wedge a block of wood under the door's bottom outside corner. Unscrew and swing the loose hinge leaf to the side. Bore out the stripped hole with a â…ś-inch-diameter bit. Spread carpenter's glue onto a matching â…ś-inch-diameter wood dowel and tap it into the hole until it's flush with the jamb. When the glue dries, drill a pilot hole into the dowel and drive a new, longer screw home. http://www.thisoldhouse.com/toh/photos/0,,20473628_20924280,00.html
Always store your good paint brushes in the cardboard sleeves in which they came. Put the brushes carefully back in the sleeves right after cleaning while they’re still damp, and the ends will stay nice and sharp. I’ve stored some of my well-used Purdy paint brushes in their original sleeves for over twenty years, and they’re still good as new. http://www.myrepurposedlife.com/2014/01/diy-tips-from-top-bloggers.html
Shorten your dryer-vent hose. First, disconnect it and vacuum it out. Then trim the hose length so that it's just long enough for you to pull the dryer a few feet out from the wall. A short and unobstructed line makes your dryer run more efficiently. Cost: Free. Savings: $25 a year on electric, gas, or propane. Bonus: Your clothes will dry about 20 percent faster. http://www.thisoldhouse.com/toh/article/0,,20250928,00.html
Spray Paint Your Doorknobs
If you've been blessed with tons of outdated 1980's brass doorknobs like me, you can easily update them with spray paint. Using the right spray paint will give you a high-end, durable result. And it's much better than paying $20+ a piece for new knobs! http://www.livelovediy.com/2012/08/update-old-doorknobs-with-spray-paint.html
Does anyone know if this will work for the hinges on a door? Will the continuous opening and closing of the door cause the new spray paint to wear off?I love this DIY home improvement tip over on livelovediy.com
If you've been blessed with tons of outdated 1980's brass doorknobs like me, you can easily update them with spray paint. Using the right spray paint will give you a high-end, durable result. And it's much better than paying $20+ a piece for new knobs! http://www.livelovediy.com/2012/08/u...ray-paint.html
also I found a great book that gives a ton of ideas on repurposing and gives some helpful tips on home improvement things especially when were all trying to get them done by ourselves lol.. by the way first time joining the chatroom! there is a lot of helpful tips on here!!Great article on ways to repurpose old window screens.
5 Things to Do with… Old Window Screens
Measuring Without A Tape Measure
Aside from memorizing the length of your stride, here are handy approximations to know:
• Dollar bill: 6 inches long
• Credit card: 2 inches wide
• Soda can: 5 inches tall
IMO nothing looks more tacky than painted hinges. Looks good until the first time you open the door.gma2rjc said:Does anyone know if this will work for the hinges on a door? Will the continuous opening and closing of the door cause the new spray paint to wear off?
