DIY lawn sprinkler system
1 reading
24K views 16 replies 9 participants last post by  nelieto060
I've been thinking it would be neat to setup a lawn sprinkler system. I'd like to go full DIY route and use standard hardware store parts like pex pipe and pex fittings. I will also want an electrically controlled valve so I can connect it to a relay and either code a scheduled/sensor based program or just set it off with my phone.
The part I'm not too sure about is where I would get sprinkler heads that pop up like the pro systems, and how do those heads connect?
Also is pex ok to use for outside? I will also want an air compressor quick connect fitting on the system so I can blow the water out in fall. Do they make such connectors that connect to regular water lines? I would probably build the manifold out of copper and paint it, just so it looks nice.
Also open to other ideas or things I need to ensure I do to make it proper.
go to one of the big box store's in the sprinkler department and get information on the sprinkler that you want to use , most have a pass out folder that you can draw your lot and where the house is and the lot line , and mail it to the company, most will design a system for you , free of charge, at least here in the state of florida HD store wil do that probly lowe's may also, i used to work at the HD ,, that is what i would do , most use pvc pipe
Take a look at sites like rainbird.com or www.hunterindustries.com. Both have a DIY product line.
Use poly pipe or PVC. I think poly is easier to work with but you will need crimp clamps and a crimping tool.
Normally you hook up a back flow preventer before the irrigation system. Hook up a standard hose bib between the house and the preventer. When you want to blow out your system, screw your air hose to the hose bib and run the valve(s). You will also want a shut off valve inside the house for the irrigation.
#4 ·
Reason I'm hoping to use pex is because I already have all the tools for that. Is there an issue with pex outside? And yeah I'll want to get a backflow, probably law. When you say PVC is that CPVC? I've never seen PVC in sizes for supply or supply related fittings like valves, only big stuff for drainage.
I'm even thinking of just using regular sprinklers and just have a hose that sticks out of the ground, but it may become victim to the lawnmower. :laughing:
I'll have to double check home depot, maybe they'll actually have the proper sprinkler heads, though I don't think so.
#6 · (Edited)
Found some heads on the HD site:
http://www.homedepot.ca/product/pop-up-sprinkler-100/958627
Anyone know what type of connection those have? It almost looks like it might just be a regular hose connector.
I've never worked with PVC pipe for supply pipes before, how do the pipes look like so I know what to look for, and do they have fittings to go to copper or pex? Most fittings that I've seen (valves etc) are for either copper or pex so it will probably be easier to do the manifold and control, check valve etc all with copper. Probably put it in a box or something then have the lines run down the side of the house.
I will probably mostly eyeball it and then set up the system above ground, and once I'm happy I will then bury the lines.
Probably going to use something like this for zone controls, much cheaper than I thought, just a quick ebay search:
http://www.ebay.ca/itm/Electric-Sol...-AC-1-2-Normally-Closed-/370725933996?pt=LH_DefaultDomain_0&hash=item5650fcd3ac
Since they're that cheap I'll probably separate into several active zones so I can have only one working at once, this will make it easier to control pressure and need less sprinkler heads per zone.
#9 ·
cpvc is a different kind , it is cream color and is used for hot water , the fitting's are different size, use pvc that is the best, the head's are eather 1/2" or 3/4" they have all the fitting's that will work , that is why i suggested to get the pass out and have the company designe it ? it is more than just getting pvc and start putting things in the ground , some head's are adjustable like 45 degree coverage and 90 degree coverage and full coverage 180 degree most are adjustable and some are fixed, differents head ?? so you will need to know more .
#14 · (Edited)
haha my water main is 1/2", 1" is WAY overkill. :laughing: This is not a commercial situation, just a home.
This is going to be a small setup. Reason I want to go DIY route is I want to be able to use commonly available hardware that I can just get at Home Depot. If I get into proprietary stuff it will get expensive and a hassle to maintain.
I was looking on ebay real quick and found lot of Rainbird stuff. Just need to figure out how it actually connects and whether or not I can even find that kind of connector at the hardware store. We don't have any in ground sprinkler companies here. In fact I'd be one of few homes that has one.
I may even jsut put some hose outlets around the yard to connect standard sprinklers to with a short lenght of hose. Then take them down off season. Though I like the idea of the adjustable popup heads.
When I design the system I will overshoot, so I can componsate for wind and what not. I can probably get away with 1-2 heads for the front lawn, the side lawn will be the trickyest as it's long and narrow, so may need a bunch of small heads in a line there. Back yard maybe 2-3 heads. Going to be a pretty small system. Front, side, back will be 3 valve zones so when I go on my phone or computer and activate the system it will only activate one zone at a time and alternate. Will probably be a simple web page where I can set it on a timer.
#12 ·
Ive worked on sprinkler systems for years and the best advice I can give you is to do what droptopz said and go with a recognized company in you area.
The biggest problem you will encounter is if the water line size and head placements and amount on each zone arent figured right, you will have areas that dont get watered and these areas show up when the grass around them looks great
They will help design the placement of heads and the size line needed to get the correct amount of water flow to do the job right
