Cutting / Ripping Aluminum Fascia
3.7K views 19 replies 8 participants last post by  Kemper100
I need to install some new aluminum fascia. The fascia I picked up at the hardware store is 8" wide and I need to rip it to 4".
What is the best method to rip this fascia?
#14 ·
Most brakes made in the last 30 years have a stainless edge so a knife can be used to score aluminum. If you don’t have a brake, score it with a straight edge and bend it off.
#13 ·
If it’s typical aluminum fascia, the best way to cut it is by using a siding brake. score it a few times with a utility knife and then bend it up to about 90 degrees. Bend it back down by hand, slowly, don’t force it. Bend it up one more time using the brake and it should snap in two. If you try to cut it with snips lengthwise, you’re going to end up with an ugly edge. And also, using a utility knife with a siding brake is normal, nothing wrong with that. Doesn’t hurt the brake.
Mike Hawkins
#12 ·
Cut some strips from the end (the 8" end) with some of the options above to see what works for you. If it is "flashing", it would be about .020". Something else could be up to .035".
Score it and bend it over, yes, it should break if it is .020" flashing.
