Replaced drywall ceiling that has hot and cold copper pipes notched into the bottom of the ceiling joists. Went to install new drywall and pipes are below the ceiling joists. Not sure if it was like this before. The pipes move some but not enough to get past the ceiling joist.
1) Does the hot water pipe get hot enough that it should not touch the wood or drywall? Also, cold water pipe ok to touch wood and drywall?
2) Reworking the copper pipes would be a fair amount of work. Can the drywall be put back up touching the pipes? Will the pipes develop a leak?
Thanks.
Thanks.
