This pump is from about 1993. I have seen it do this before when we lost power for a second and it reversed the pump. However, I recently returned home to hear only a slightly "different" hiss from the A coil than I was used it. I touched the line set and determined the liquid was cold and suction was hot.
So I shut down for a bit and restarted. It is still doing it!! I am really confused now. Could this be the capacitor? Usually a cap start motor will not start with no cap and the pump fires right up and does not sound too bad other than running backwards.
This is a heat pump BUT I cut the reverse valve out myself so I know it no longer exists so no way that could be it.
Help!
UPDATE: I did verify that the run capacitor is perfect. I can find no other issues. I started it direct on the compressor with the contactor and it seems to start perfect and really does not make any loud racket but is still running backwards.
Help!
