Sort of a plumbing question....although it's for an air compressor.
I am replacing my air compressor pump and will need to re-plumb. The tank check valve has a 1/2" (tube) compression fitting. I want to convert this to 1/2" NPT (female NPT ideal but I can make male work too).
Is there an adapter that will convert male compression threads (at the bottom of the image below) to NPT threads?
