Hello Kind Folks,
Here is my scenario. One MAIN PANEL and two sub-panels. All located within same building. SUB-PANEL B supplies power to few dedicated circuits in my home office in the rear of the house; no big power draw there hence 60A feed to sub-panel way more than adequate.
I currently have a portable inverter type generator that supplies 120V at little over 25Amps. I'd like to use this to supply power to devices connected only to SUB-PANEL B; I am not worried about running a fridge or the other stuff, only the equipment that is connected in that home office. There would be an interlock on that SUB-PANEL B as to disengage it from the MAIN PANEL when generator is connected.
The reason I am not making a connection to the MAIN PANEL is two fold. My current generator is too small to supply power to the whole house and the MAIN panel is in the front of the house while I can only leave the generator running in the back of the house, running long leads through the house at the moment is not an option.
Please let me know if this is possible. Below a drawing for you consideration :wink2:.
