I outlined my plan for the window well and retaining walls with the inspector today.
The well is 6'6" tall from subgrade to top of well, which is 6" below finish floor and siding.
My plan is to cut and set up the 3 outsides of the form plywood, and then put L-bar inside it at 1' on center vertical and across the bottom. Tie a horizontal U at top and mid points, then set up interior form panels with snap ties and shoes for a 4" wall and 6" floor.
I'll put two pairs of imbeds on the inside form for a ladder on one side.
I'm setting it up as an egress window, all the basement windows are egress capable.
My rebar supplier will bend anything for me, so I'll get 6' by 3' bends I can tie together across the bottom, and a couple of U-bends for the top and mid horizontals.
the retaining walls are 4' high with a 2' leg underneath the fill side. They come out from the house 6', and then do a 3' 45 bend away from the fill side to provide support in compression.
I can make those 6" thick if needed, but was planning 4" walls and 6" foundation leg.
