Concrete slab for oil tank
7.3K views 26 replies 7 participants last post by  darrylwmiller
I am pouring a 4' x 5' slab for a Roth oil tank to be installed on and am in Northern ontario, so we see the temperature dip into -30c. Our soil has good drainage, and the slab will be directly next to the house.
My question is, what is the best way to pour this? Neighbour down the street has the same tank on the same size slab with poly vapour barrier under the slab. I was going to pour gravel and concrete on top with rebar in the middle. Should I bother with vapor barrier considering it is outside, should I bother with gravel as soil has good a good drain? I am using 2x6's for the framing.
#8 · (Edited)
#9 ·
Yep, that is the method that I learned a half century ago.
Dampen the ground to prevent any of the mixture from being denied it's needed water to cure.
Then in over 80 degree weather either place a wet blanket, or keep a bit of sprinkle on the slab to prevent scaling.
Heat will dry the outer layers and cure them, but the inner layers are still green, and in a few days to months the scaling happens and ruins the slab.
Be sure that you have undisturbed ground underneath, to prevent any settling, and making the slab unlevel.
That would make the tank draw oddly, and might cause a problem if unlevel enough.
ED
Reactions: SeniorSitizen
#5 · (Edited)
I am not sure whether this is a non-problem but I have a general question: When concrete is poured or mixed in a fence pole hole or in a form open to the ground below, what prevents the more liquid components from percolating into the ground leaving the more coarse components no longer in the correct ingredient proportions including water content? Wouldn't a poly' sheet underneath help?
#18 ·
Well I think I will have to rip it out and try again not happy with what appears to be scaling on surface of concrete and the sides look like they have holes in them. Not sure if this would be adequate for holding such a heavy thing such as a full oil tank. I had posted another thread regarding this but I can't figure out how to delete it to just keep this one thread active. Image links posted below of finished job.
https://ibb.co/59Wpz1v https://ibb.co/16P7hdS
https://ibb.co/T88FxW7 https://ibb.co/kJNV1L2
https://ibb.co/fXLVnjv
#24 ·
What was the ambient temperature at the time of curing?
Did you keep it damp with a wet blanket or wet cloths during a hot day?
Premature flaking is a sign of an improper curing process, usually a dry hot day, and the surface cured, but the interior was still green, and cured later, and caused damage that is best R&R'ed.
ED
